black fingerboard dye OK under FP? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=24052 |
Author: | JasonM [ Mon Oct 05, 2009 9:24 am ] |
Post subject: | black fingerboard dye OK under FP? |
Does anyone know of any issues with using black alcohol based fingerboard dye on back and sides, and then french polishing over? thanks! |
Author: | Steve Kinnaird [ Mon Oct 05, 2009 12:52 pm ] |
Post subject: | Re: black fingerboard dye OK under FP? |
No first-hand knowledge here, but I'd guess that the alcohol in the FP would partially dissolve the alcohol based stain, picking up color from the sides/back as you polished. Seems that the first step in your scenario should be a spray coat, lightly applied, that would seal in the stain. Then polish as usual. As always, a test run will teach you volumes...practice on some scrap till you've got a usable technique. Good luck, Steve |
